Revs up when fired up?
Old 06-15-2010, 03:30 AM
F-BodyMind's Avatar
Question Revs up when fired up?
The other day i had a yank SS3600 put in and a few days later i noticed that my car revs up to 1100-1300 rpm's when turned on and slowly comes down to normal to 750 or so. Also when driving at slow speeds and i let off the gas the car sometimes doesnt slow down, it actually speeds up little by little.. What do you guys think might be going on? I also noticed my belt wiggling a bit but the pulleys look solid so i know its time for a new belt but i was told this was most likely not the problem.
BTW its a 99 TA with 125,XXX miles with only bolt ons.
Old 06-15-2010, 03:38 AM
00MaroonZ28's Avatar
Have ya tuned the car since the new torque converter?
Old 06-15-2010, 06:18 AM
fleetmgr's Avatar
I'd look for a smallish vacuum leak.
Old 06-15-2010, 09:36 AM
blades11b's Avatar
im goin with vacume leak man maybe you disconnected something check it out
Old 06-15-2010, 12:52 PM
sscamaroburn02's Avatar
check your vacuum lines on intake. mine was disconnected and causing idling issues
Old 06-16-2010, 04:03 AM
F-BodyMind's Avatar
No i havent, ima send it to frost soon though ive heard he does good work.
Old 06-16-2010, 04:06 AM
F-BodyMind's Avatar
Ill check my vacuum lines tomorrow morning, hope thats the issue.
