Need help. 911. starter or electrical
When I goto start the car there is a decent loudness pop. cant tell if its an electrical pop or a really loud switch. its seems to either be inside the car or under it. car wont start. (after about 5 attempts with the pop if I just hold the key over in the start position it would fire up and be fine. turn it off and on it fires up fine again.) I had the battery checked, its good, connections are solid. pulled terminals off battery and hooked up to a volt meter and it didnt beep so im not lead to believe its a short. any ideas? this is my work car and I need it up and going strong. thanks!
also if its the starter.. how do I remove it?
edit, all lights and radio come on. there is only 1 pop. not multiple.
new symptom just happening, now the radio is not coming on. i tried switching out the relay/fuse thingy under the hood, traded the fan #1 over to igntition (i think, its burnt out so i cant really read it) and starter fuse relay thingy, same issue
