Starting issuesss
Starting issuesss
I started my car this morning and drove it to work then went to start it again after work It, turn the key.. put the clutch in and nothing in the start position. Took the key out and tried again.. Started right up.
Has been hit or miss for the past few days, today in the mcdonalds line shut it off to order(open cutout).. went to start it and it and it began to start and died out, then tried again cranked right up.
Thanks
Thanks
im having the same problem with my camaro also. like you said its a hit or miss.. sometimes is will start sometimes it wont. i cannot figure out what the problem is. turn the key to crank but nothing happens. lights on dash work but just no crank. did you figure out the problem yet?
