VATS problem
Old 07-12-2010, 11:22 AM
blown03mustang's Avatar
Default VATS problem
ok so im having problem with the vats (im assuming), its the usual, car cranks, runs for 3 seconds, and shuts off. pump continues to run after and car dies. when you turn the on the security light comes on and goes off like normal, when you turn the car over though its solid. ive had the vats turned off in the pcm and done the resistor mod on the two white wires under the steering column. WHAT NEXT??? im stumped
Old 07-13-2010, 11:29 AM
anybody?
