battery cable is loose some time
Old 07-24-2010, 05:34 PM
killagt's Avatar
Default battery cable is loose some time
the thing that hold my battery down is loosing, and it make my battery moving around a bit, and some time it lost connect and I cant start the car, I have to pop the hood and wiggly the battery to make it connect again, I tight the 2 bolt that connect to the battery tight as I can, but some time it lost connection, where else I need to look for loose cable ? cause I know i tight the hell out off those 2 bolt that connect to the battery. thanks
Old 07-24-2010, 06:33 PM
fleetmgr's Avatar
The side terminal batteries are bad for this. Replace the battery connectors on the ends of both cables.
