So...
So...
Today i took off the belt that goes around the ac comp because i dont use the ac being that its not working, second i put the resistor for the cags and cut part of the egr tube that goes behind the throttle body and now my car is stuttering around 2400+ rpms in 2nd and 3rd, what the duece? im not throwing any codes. anyone?
ok so last night when i was trying to bring her above 3k rpm's the stuttering happened sometimes in 2nd and 3rd but 4th it was stuttering bad then after a few seconds the ses came on. gonna check code today at advanced
I doubt if both 02's are bad all of a sudden. What's the code? I'm thinking the seal at the EGR tube/intake is leaking unmetered air throwing the fueling off.
make sure that line is plugged up. you should be able to put a freeze plug on a 98 alot easier then the 00-02 model EGR/AIR setup. On my 01 that line feeds in behind the Intake manifold. So i plugged the tube over an exposed thread on the fuel rail for now.
