Starting problem. need help asap!
i'm going to leave work and my '02 camaro won't start. i turn the key foreward and nothing at all. i have juice for sure. i have "stealth" security system but i bypassed that. i tried jumping the two terminals on the starter and the starter spins but does not jump into the flywheel to try to spin the motor.(i hear that may be normal) i can hear a small click by the starter/ignition fuse relays under the hood when trying to start it. any ideas?? please help!! thanks. I may go by a starter and just try it...
sounds like vats is going bad. is ur security light on? here a good write up on the bypass to fix/diagnose it. click on link below.
http://www.ls1.com/forums/showthread...ht=bypass+VATS
