Need Help Solving Electrical Gremlin! 03 Tahoe 5.3
Old 08-27-2010, 03:57 PM
LustrousWS6's Avatar
Default Need Help Solving Electrical Gremlin! 03 Tahoe 5.3
Alright here's the deal - 03 Tahoe 5.3
This thing keeps sucking batteries dry (3 so far). New battery was put in after each change and every time it was sucked dry (not even a click when you turn the key), if you put a charger on it, it would start right up no problem. Problem is most common after sitting over night (my guess was a short). Alternator was checked and tested good, problem continued - new alternator - still continued. Dealership ran a full test to see if there was anything draining the battery while the vehicle was off or if it was pulling more charge than it should under any conditions they could put it through. No one can tell wtf is wrong with this thing but it keeps killing batteries. Any insightful help would be appreciated. Please note this is a family car so descriptions may not be 'perfect' - I'm just going off of how things were explained to me. Multiple mechanics and a couple dealerships don't have a clue what's going on here so help me out, tech! Thanks.
Old 08-27-2010, 08:38 PM
fleetmgr's Avatar
Pretty serious draw to kill it overnight (as in more than just an LED or something like it).
Get an ammeter that will measure more than just a couple of amps. Hook it inline with the + terminal of the batt. Pull fuses one by one until the draw goes away. Once you find the right circuit, start looking for the problem component.
Old 08-28-2010, 11:46 AM
I'm sorry if my first description was a lil misleading - the dealership tried to put an ammeter to it (milliamps) and found no abnormal draws were found. It doesn't do it over night but after 2 to 4 weeks (normal driving it around every day), one day when they go out to start it in the morning, it'll be dead - not even a click.
I did suggest that he get an ammeter and test it every now and then as I think the draw is intermittent, if it shows then he can try and track it down. Any more insight would be appreciated!
Old 08-31-2010, 02:44 AM
Bump. Plz guys - any help would be appreciated. Need to solve this.
Old 08-31-2010, 04:44 AM
HotSilverBird's Avatar
Actually you already answered your question, you have a draw someplace....track it down. Not always easy but I would start by comparing another truck at the dealer.
