Oil Drain Plug
Oil Drain Plug
So I'm trying to change my oil. Simple enough and I've done it before. Yet when I go to remove the drain plug it refuses to budge, something got it stuck. I've got the right sized wrench and I know everything works, yet for some reason this time the plug refuses to move and instead the sides of the bolt are starting of give, so I had to back off it before I rounded it out.
Any ideas on what could be causing it to stick and experience on how to get it out?
1 Post
Looking at the bolt, turn it leftwards. Use a six-sided wrench or socket. Use a breaker bar or pipe if you need to.
After you get it off, don't take it to a IffyLube any more (if you did), and remember bolts don't need to be tightened to within an inch of their lives. Maybe get a torque wrench.
If you cross-threaded it, get a new plug that cuts new threads.
