card in bike spoke sound on decel/closed throttle
Old 11-05-2010, 06:14 PM
Tongboy's Avatar
Default card in bike spoke sound on decel/closed throttle
Car is a swap car so that certainly might explain it....
I've searched various ls1 forums and found a few possibilities for this sound, lifters, rockers, exhaust leaks, etc.
I wanted to post to see if there were any better specific things, it's a unique enough sound that it seems like it would be pinpointed semi-easily enough.
symptoms: accelerate to any rpm over ~1500rpms and let off throttle - still in gear - card in spoke sound from engine bay, the higher the rpm the louder/more frequent the sound is. roll back on the throttle - even the slightest bit and the sound goes away.
any help would be appreciated.
Old 11-05-2010, 06:49 PM
Sarge91's Avatar
Check the flexplate/ flywheel for cracks etc.
Old 11-05-2010, 08:35 PM
blitzace12's Avatar
i have heard that a bad gasket on the air pipe can cause this sound. Not sure if you even have the air system.
Old 11-10-2010, 11:43 AM
98cherrySS's Avatar
Air valves... Try blocking off the air valves and see if it continues.
Quick Reply: card in bike spoke sound on decel/closed throttle
