Power Steering whining time to replace!
Old 01-02-2011, 03:39 PM
vinny01ss's Avatar
Default Power Steering whining time to replace!
So it's time, my P/S pump is whining like crazy. My question is, is it actually the pump or the pulley. The reservoir is fine and I see no sign of leakage anywhere. Thoughts and input greatly appreciated.
Old 01-02-2011, 04:41 PM
Adam2001WS6's Avatar
Whining is generally caused by low fluid levels.
Old 01-02-2011, 04:42 PM
By the way, why are you jumping to replacing the pump? Is it just low on powering steering fluid?
Old 01-02-2011, 04:57 PM
vinny01ss's Avatar
Not jumping the gun, being that the fluid level is where is suppose to be
And it's not leaking. It's passed it's prime.
Old 01-02-2011, 09:02 PM
BRUTL's Avatar
The pulley is pressed on to the P/S pump shaft, any bearings are integral to the pump, so it's not the pulley, there's no way it can be. Are you sure you don't have a hole in the return line? They don't always leak, they can suck air into the system too. Rack can do that too.
Old 01-02-2011, 11:38 PM
vinny01ss's Avatar
Thanks for he input, didnt think about that will take a look in the morning.
Old 01-03-2011, 11:42 AM
Save the manuals!
wssix99's Avatar
There are threads that describe a while associated with the pulley. You may want to search.
