TCS,Brake,ABS
Old 04-07-2011, 10:04 PM
mhegwood02'WS6's Avatar
Default TCS,Brake,ABS
My TCS,Emergency Brake,and ABS lights come on and TCS goes off after the car has ran for a small amount of time. There is a problem that I can't find and it's really irratating to see my idiot lights come on and the car runs fine.
Old 04-08-2011, 01:57 AM
myk
myk's Avatar
Easiest thing to do is check your rear-wheel speed sensors. Over time they can become coated in metallic debris, interfering with the way the reluctor ring interacts with the wheel speed sensors. Give it a shot and let us know what happens...
Old 04-08-2011, 02:08 AM
jsteele90's Avatar
yeah sounds like a ABS sensor took a crap
Old 04-08-2011, 11:19 PM
Roger that, been there done that plus I replaced the front hubs to make sure the internal speed sensors in the front hubs weren't causing the problem to occur. I've spoke to a speed shop owner and several GM dealerships and they said it could possibly be ECM that cost over $900.00, Go figure huh!
Old 04-08-2011, 11:27 PM
myk
myk's Avatar
Well...before I'd say ECM I'd check out the ABS module first. Now, I don't know how to diagnose the module without a scan tool-maybe someone else here does? Also, $900? I know the ABS module, BCM and PCM's aren't cheap, but $900?
Old 04-08-2011, 11:57 PM
meydron's Avatar
I had the same problem for a while and the problem was just that my battery was weak Put a new battery in and it worked fine. Might not be your issue but wouldn't hurt to check it before spending money.
Old 04-16-2011, 12:47 PM
pchapin's Avatar
I have the same problem. After four years I finally took it to Chevy dealer this morning. ABS ECM, $990 plus install. GM part direct $587. Looking for a used one.
