Water pump?
Water pump?
So I just finished my header install and while under the car I noticed the water pump seems to have antifreeze build up under neath it... It's not dropping but can anyone think of where it could be leaking?
I had a leak which I thought was the water pump, but after I notice nothing leaking from the center of the pump I found out it was the heater hose. Not sure if you know where those are located, but on the left side of the water pump are 2 small hoses. One of the hose was starting to rot and was causing the leak. I replaced with 2 hoses from that advance store for 30.00 beats the hell out of the GM hoses for 150.00.
