Weird clunking sound
Old 06-27-2011, 11:26 PM
TXZ28LS1's Avatar
Default Weird clunking sound
Hey guys, on the way back i noticed a weird sound coming from the rear driver side. It sounded like the lugnuts were loose, or the tire got flat or coming off. But when i pulled over and checked everything was perfect. Also when i was coming to a stop, it made a slight squeak noise. But i just changed my pads/rotors? No leaks or anything. I noticed when slowed down or came to a stop the sound of course went away.... Any ideas?
Old 06-28-2011, 04:50 AM
elwood2's Avatar
Try putting the rear on jackstands and have someone put the car in gear while you listen around the back to try and figure out what it is. Take the tire off the side to see if you can see anything. Could be the rotor rubbing on something or a bad bearing.
Old 06-28-2011, 09:24 PM
TXZ28LS1's Avatar
Thanks elwood,
Honestly, i think its my tranny!! It took a dump!
