99 z28 new start still no spark
i have a 99 z28 just replaced starter due to the old one being bad. got new one on when key is turned it turns but no spark. any ideas ? battery and everything checks out good no codes are showing
did you test for no spark or are you assuming? check fuel pressure and air filter are some other easy to check symptoms. maybe crank or cam sensor loose connections or burned wire.
