98 t/a front passenger side blinker
Old 07-07-2011, 11:42 AM
98 White T/A's Avatar
Default 98 t/a front passenger side blinker
Ok so the other night i was driving and my right blinker wasnt working. I pulled over and was messing with the lights turning them all on and off, and the front right park/blinker light, was stuttering off/on, and eventually stayed off. Went and got the light to change it and the old light looks very corroded, the plug did to a little, so i cleaned it up a little and put the new light in, and!.... still not working.
Has any1 else had this problem? or should i just buy a new plug and wire it in.
Old 07-07-2011, 03:48 PM
ws6outlaw's Avatar
had this problem and it was my plug. put a new one in and its been working ever since. if none of your other lights are doing this then i would think it was in the bulb or the plug and since you've already eliminated the bulb..
Old 07-07-2011, 09:37 PM
ok thanks, I just wanted to make sure to see if any1 else had the problem. I might try to clean it up a little more before i buy a new plug, anyways, thanks!
Old 07-08-2011, 11:01 AM
Save the manuals!
wssix99's Avatar
If you search, you should be able to find the right thread. No need to change the plug. You can buy a new socket insert from Mouser Electronics, save a ton of money, and skip splicing in a new socket assembly.
