Oil coming from the crank sensor?
Old 08-25-2011, 03:00 PM
02v8ta's Avatar
Default Oil coming from the crank sensor?
Car is in the sig. The crank sensor was replaced a few months ago and now it kinda looks oil soaked or oil is coming from it. Is this normal or does something need to be fixed? Is it complicated?
Old 08-25-2011, 04:00 PM
01ssreda4's Avatar
Simple o ring seals it. I would replace it.
Old 08-25-2011, 05:48 PM
02v8ta's Avatar
Part number or links or anything ? How hard is it to do?
Old 08-26-2011, 02:05 AM
01ssreda4's Avatar
One bolt, pull the sensor out, swap o rings, reinstall.
Old 08-26-2011, 07:00 PM
02v8ta's Avatar
Is there a way or place to get the o ring before i take it out. I've read you have to go to the dealer, i hate our dealer... he's a *****. Where would you get it from?
Old 08-27-2011, 03:38 PM
02v8ta's Avatar
Bump 2 things...
1. Is this the right replacement. I'll be so happy.
http://compare.ebay.com/like/3005772...=sbar&_lwgsi=y
2. Sooo should i do my oil change before replacing the o-ring. Or even with it off will it just slowly seep? Does it pop in & out no problems?
Old 08-28-2011, 02:22 AM
01ssreda4's Avatar
That oring looks right if the picture is accurate. Oil will not leak out because it is above the oil level line....and yes it comes right in/out.
