Bad MAF?
Bad MAF?
Hey guys,
I have an 80MM Delphi MAF on my 2001 T/A..it has been running awesome lately and I've had no issue's at all...for once.
Today I took it out to the car was and spent a good 2 minutes spraying down the engine bay but stayed away (as much as possible) from the intake, coils and pcm.
About halfway home I noticed that it had some hesitation..it only does it under partial load, and at WOT, BUT I am throwing some O2 codes, Bank 1 Sensor 1 I believe and Bank 2 Sensor 2. I know it also threw a faulty catlytic convertor code, but I'm not too sure which side. I know that the clogged cat and cause misfire/ hesitation (which I have, the misfire is very noticeable at idle.)
Over the summer I changed plugs so I'm doubting it's those, they are NGK Tr55's gapped at factory spec. So all I have left is wires/coils, a leaky injector O-ring (leaked in water and possibly fouled plug?) Or a bad MAF. I will try to post up vids, i do have a 5.3L LM7 truck that I can swap MAFS with but I will do that as a last resort to see if that;s what it really is, so where should I start?
Basically, have misfire, think its MAF, where do I start?
Since you say that the problems didn't start until you washed the engine I would wait for the car to dry out before you rush out and buy 02 sensors and a 'cat. I've heard of people spraying their engines down and having problems afterwards.
I know a lot of people swear by washing their engines but I've never agreed by it: water and electronics don't mix and there are enough components in there to make it not worth the risk...
Like already said water and engine bays do not mix. I just stick to hand washing mine. If you are throwing a code for bank 1 sensor 1 that may very well be your problem. Let your car "dry" out clean your maf clear the codes and see if they come back or still get the misfire.
