Loss of idle quality in gear and breaking up at mid rpms
Old 10-08-2011, 08:06 PM
jdiddyws6's Avatar
Default Loss of idle quality in gear and breaking up at mid rpms
I have a 418 that I've had no problems out of. I was driving it today and it started hunting for idle at stop lights with the car in gear, sometimes dying. It's fluctuating by as much as 1000rpms. It is also breaking up at about 3k rpms, but cleans up a little bit they higher up you go. I changed the plugs with no improvement. Also, I was underneath it contemplating how to attack #8, and I noticed an 02 was unplugged. This had to be done earlier in the summer when I put some extenders in, but the car is rarely driven. Any Ideas?
Old 10-09-2011, 02:09 PM
jdiddyws6's Avatar
Car is throwing a maf code. Going to try and find one to troubleshoot with/
Old 10-10-2011, 12:02 AM
usnfenix's Avatar
i had a similar prob. it was o2 sensors.
Old 10-10-2011, 12:10 AM
lemons12's Avatar
That problem is definitely pointing at bad 02s...
I would unplug the maf while it is acting up, that will help rule it out.
If that isn't it, I would replace the o2s.
Let us know.
Old 10-12-2011, 08:21 PM
jdiddyws6's Avatar
Let us know.
The 02's are very fresh. Put them in over the summer, and the car is driven just a few times a month. They have < 1000 miles on them.
Old 12-25-2011, 04:24 PM
jdiddyws6's Avatar
Put a different maf in it. Problem is still the same. If i unplug it, it dies immediately.
Old 12-25-2011, 05:02 PM
blade2222's Avatar
Unplug the maf then run the car and see how it runs.
Old 12-25-2011, 05:06 PM
jdiddyws6's Avatar
I did. It dies immediatly
Old 12-26-2011, 01:31 PM
jdiddyws6's Avatar
Hooked a truck coil pack rack up on driver then passenger, still breaks up and doesn't hold idle well.
Old 12-27-2011, 09:37 AM
jdiddyws6's Avatar
Tried 2 more MAFS with no luck. Throwing p0102 and 02 codes. It doesn't want to hold an idle, but it is no longer breaking up on acceleration.
Old 12-27-2011, 09:04 PM
jdiddyws6's Avatar
Well, found the problem. Evidentially the 02 sensors and the MAF are on the same fused circuit. Found a guy with the same problem, and he determined that the 02 grounded out and popped the fuse "engine control". Found it blown, changed it, and it's good to go.
