Odometer went blank.
Old 10-10-2011, 10:09 AM
MM98's Avatar
Default Odometer went blank.
After installing my new rachet shifter & carpet, I was testing the reverse lights & noticed my odometer is blank.. It is lit up, but no numbers. Any ideas? I also pulled the airbags & module & noticed there was a single ground wire bolted to the module bracket.. I just assumed it was part of the module harness.. Any ideas what that ground is for? Also, are there any fuses that tie into the cluster? Any help is appreciated!!!
Quick Reply: Odometer went blank.
