electrical issue.. where to start..?
Old 12-16-2011, 01:42 PM
stephen4036's Avatar
Default electrical issue.. where to start..?
ok, so sometimes I lose my radio, fogs, and window power.. sometimes it never flickers during the whole drive.. and sometimes none of those come on at all the whole drive.. usually its back and forth between on and off.. dont really care if i can hear bitches singing on my radio.. just be nice for it to work so when i get somewhere I can roll the windows up..
maybe someone has a map of all the grounds in the engine bay? or what i should check first?
anyhelp is appreciated.. car runs great.. just want to fix this issue.
Old 12-16-2011, 11:57 PM
perezpowerbuilders's Avatar
you Need to get wiring diagrams for your particular model year...follow the electrical path from your battery to fuses and finally wiring to grounds...a test light and or multimeter will help you find the solution to your problems....sounds like you have a broken/loose wire somewhere
Old 12-17-2011, 06:18 AM
im sure this forum has a diagram somewhere thanks.
