Help! Wiper speeds messed up!
Old 12-16-2011, 08:40 PM
WhiteKnight '01's Avatar
Default Help! Wiper speeds messed up!
So it was raining today, I took my car out and turned the wipers onto the 3rd setting. First thing I noticed was they were going way too fast for 3, more like on the 5th setting or so. I quickly turned it off and then put it onto 1, the lowest setting...the speed continued. I turned it to the off position. It still continued on speed 5! Eventually it turned off. I have tried all of the speeds, 1 and 2 will work for awhile but then they increase in speed to setting 5, when I turn it off it doesn't turn off right away, keeps going...eventually shutting off.
While it was raining the whole day, it wasn't a big problem, except the speed was too fast for the light drizzle. This is still a very annoying problem. Does anyone have any idea what might be wrong? What can I do to fix this?
I thought of checking the fuses. Is there a fuse for this that may need to be replaced? I also though of disconnecting the battery, but have not done that yet.
Does anyone have any idea what may be wrong?
Old 12-16-2011, 10:39 PM
Starz T/A 17's Avatar
If it was a fuse they wouldn't work at all. My guess is the wiper switch went bad as I really can't think of anything else that would cause that to happen.
Old 12-16-2011, 10:40 PM
The wiper switch? Well ****, how the hell would I replace that?
It still doesn't seem like it explains the wipers going on higher settings and then lower settings at random, and not wanting to turn off.
Old 12-16-2011, 10:44 PM
baalic's Avatar
It's actually not that hard of a fix, Fbodies have used the same "blinker/wiper" bar for like 20 something years...... but, I would check the wiper relay. It controls the speed not the actual bar... It's like a fuse, but it looks like a little metal box in the fuse panel.....
Someone correct me if im wrong..
Old 12-16-2011, 11:01 PM
Any idea on how to fix the switch? I wouldn't know where to begin.
Old 12-21-2011, 01:18 AM
baalic's Avatar
Should be a little Plug anda couple screws .. Dont rememver if the eheel has to come off or not... Been a while since i broke one
Quick Reply: Help! Wiper speeds messed up!
