2000 Trans Am Door lock issue....HELP
When using the keyless entry the door unlocks on the drivers side but will not lock. Replaced the actuator but it did not solve the problem.
Other issues. Passenger side seat will not move in or out. There is a cross bar that unlatches the outside slide. Where do you get one of these.
not the radio but the window possibly yes check connections sounds to me it is fine though the body control module reverses the polarity to make the motor lock and unlock by switching relays iternally
you may have a problem with wiring check to see if the switch will operate the lock normally i can get a wiring diagram tomorrow and walk you threw it do you have a voltmeter
