Water pump moves
Old 01-02-2012, 01:35 AM
aaron564's Avatar
Red face Water pump moves
ok today my serpentine belt snapped and when putting the new one on i noticed the waterpump was able to be moved up and down when i grabed it is that normal on this car it is a 2000 pontiac firebird 3.8 ?
Old 01-02-2012, 03:27 AM
Crimsonnaire's Avatar
If there's a play in your water pump pulley, it means that the shaft and bearing chamber is getting worn. Once the clearance reaches the threshold, it will leak coolant. Knowing this, you may or may not want to replace the pump while you're ahead.
Old 01-02-2012, 05:16 AM
myk
myk's Avatar
You mean the pulley moved or the entire housing moved?
Old 01-02-2012, 02:02 PM
aaron564's Avatar
like i was able to grab the water pump and move it up and down and everything that was hooked up to it moved with it
Old 01-02-2012, 02:33 PM
1sick'98WS6's Avatar
So the bolts holding the water pump to the engine are loose? If just the pulley has any play in it, then replace it as stated above
Old 01-02-2012, 03:37 PM
aaron564's Avatar
ok thanks guys
