wierd light flicker
Old 01-25-2012, 10:17 PM
mconway68w's Avatar
Default wierd light flicker
I changed knock sensors and harness today. Car runs fine, no codes. At idle, everything is fine, but if I touch the throttle any amount, all lights start flickering. If I unplug the negative from the battery while its running, it stops doing it. It's not the alternator. When I let off the gas and it gets back to idle, everything is steady again. It's so strange that it only does it when the battery is plugged up and I give it some gas. Anyone heard of this?
Old 01-25-2012, 10:20 PM
mconway68w's Avatar
Oh, and voltage is showing normal. Maybe something plugged up wired, but I checked my work and it all seems fine.
