Window motor... HELP!!!
I've done this, and would/will do it again. It's very simple on these cars. And once those access holes are drilled and there are no motor rivits to remove, future replacements are even easier.
I really don't see how it could be easier to remove the whole regulator, at least in the case of these cars.
Sorry to jack this thread but my window is stuck half way down (or half way up) and it will not move at all, I pulled everything off and after a bit of research and poking around on the door this is what I found.... Looks to me as if the motor has been replaced before...
So I need to replace it now, how in the hell do I get the window to move up? I've tried holding the button to roll the window up and pulling it up but it only moves about an inch then when I let go it drops back down
remove those 3 screws remove the window motor , then pull the window up manually... hold the window in place with a clamp and wood block...if the widow still wont come up after removing the motor, then regulator or something else is messed up....goodluck to you.
