SERVICE ENGINE SOON light code#P1415
Hey everyone if anyone can help on this that would be great.
I took my car to autozone(02 ws6) and got the test done on it.
Im going to copy what it says on the paper down below.
Troubleshooting code1415
Definition
Air system bank 1 fault
Explantion:
During the air system test the ecm looks for a change in the 02 sensor voltage- no change was detected
Probable cause:
air pump electrical circuit fault
blocked air system
failed air pump.
I do have a K and N full air intake that had a little piece of the plastic off the filter on the right side before the light came on last night. today I fixed it where there isnt a hole between. could it be there was to much air going into the filter and caused the light to turn on? thanks
Definition
Explantion:
Probable cause:
blocked air system
failed air pump.
