Is a way to bypass the DRL module?
Old 06-18-2012, 08:59 AM
Zombiesoldier's Avatar
Default Is a way to bypass the DRL module?
On my 01 T/A the drl module seems to have failed. Is there a way to bypass it without cutting any wires, to test it to make sure it is the module, before I spend the money on a new one? I just don't want to buy a new one and it not be the problem.
My symptoms are no drl's, no turn signals in front, no 4 ways in the front, and if I try to put on just the fog lights the headlights open, but headlights just don't light up untill I flip the headlight switch to the headlight on position.
Old 06-18-2012, 11:26 AM
Super Moderator
Reckless's Avatar
A lot of people are driving around just fine with their DRL box unplugged. It was one of the first things I did on my old car. Not sure how it would affect the other items?
Old 06-20-2012, 12:00 PM
Nathan C's Avatar
If the headlights pop up but don't turn on when you just have the fog lights on you may have a stripped gear. It could be two different issues at the same time.
Quick Reply: Is a way to bypass the DRL module?
