Restoring Power Window, Wiring Help.
Old 06-26-2012, 02:27 AM
T/A Medic's Avatar
Default Restoring Power Window, Wiring Help.
Long time ago I took all the wiring out of the car... ( Drag Car )
I've realized that not having the ability to operate my windows is fail sauce...
Need some help with wiring.
I've looked through multiple posts but wiring diagrams are giving me issues...
I have a new AC Delco Connector for the driver window switch... and a new connectors for the power window motors.
How do I go about hooking all this up... No express down mod.
Wires Go Where?
TYIA
A - Ground ?
B - Window Motor Wire 1 ? - Pass Side
C - Window Motor Wire 2 ? - Pass Side
D - Window Motor Wire 1 ? - Driver Side
E - Window Motor Wire 2 ? - Driver Side
F - 12v Power - 30amp Inline Fuse ?
if window goes in wrong direction when activating the switch i would just switch D/E and B/C
Old 06-27-2012, 12:32 AM
T/A Medic's Avatar
This setup works... If your windows don't go up or down with switch direction properly, just swap wires to the motor.
Quick Reply: Restoring Power Window, Wiring Help.
