cooling fans won't come on
Old 03-06-2013, 06:01 AM
JRWMS's Avatar
Default cooling fans won't come on
My cooling fans work if I put power to them directly they will not come on automatically. On my 1997 Camaro Hendricks addition LT1 I can't get the fans to work unless I put power to them directly. Any help would be greatly appreciated. Will it cause any problems if I just disconnected them and ran switches to manually turn them off and on. Can I put an aftermarket temp. gauge on this car and keep factory gauge as well
Thank you for any help you may be able to provide I know nothing about electronics all my other cars were built before computers
jack
Old 03-07-2013, 03:26 PM
JohnS Z28's Avatar
Fuses probably
Old 03-10-2013, 09:28 PM
rg501's Avatar
or relays
Old 03-12-2013, 09:25 PM
rg501's Avatar
actually, the same thing is going on with my car, and I just threw a switch in there to turn them on and off. haven't had any problems with it
Old 03-14-2013, 03:30 PM
Mista Blazer's Avatar
Check fuse first, if fuse looks good then get the relay replaced. if the relays *yes more then one, there should be 3* replace all three and if still no fix take them back and get your money back
Old 03-15-2013, 06:51 AM
LT1Form350's Avatar
This is very common on the lt's mine does it too, replacing fuses and relays didn't work for me. I've heard the computer just 'forgets' to turn the fans on. But mine only come on with the A/C. I'm gonna look into wiring up my fans. Good luck
Quick Reply: cooling fans won't come on
