Aftermarket knock sensors
Old 06-20-2013, 01:20 PM
ZForce1's Avatar
Default Aftermarket knock sensors
Has anyone had problems with aftermarket knock sensors? Several months back I got a code for knock sensor bank 2 (PO442 I believe). I replaced both knock sensors and the harness. I also put a bead of RTV arount the top of the sensors IAW the service bulletin or whatever it was. about 6 mos later the same code came back. Knock sensor bank 2. I can't keep removing that intake and replacing knock sensors every few months. Is there anything else that could cause that code besides the sensors and the harness? Or is it like O2 sensors that I have heard you have to get from a dealer or you will get a code again (if you get from an autoparts store)? I got the sensors from Oreilly. Thoughts/experiences?
Thanks
Old 06-20-2013, 05:21 PM
SinisterBirdWS6's Avatar
I put AC Delco's in mine, thats what i was recommended on here. Got them from amazon. I had the same problem, replaced both sensors and its been happy ever since. Make sure your harness is not pinched anywhere and i would replace it too if you havent yet. Also, check if oil came through the grommets in the valley cover, not sure but it might ruin the connector.
Old 06-20-2013, 07:55 PM
sjsingle1's Avatar
not no.....BUT HELL NO !!!!...........oem only.....ask me how i know
Old 06-22-2013, 05:52 PM
ZForce1's Avatar
how do you know
Old 06-22-2013, 06:06 PM
sjsingle1's Avatar
bought auto zone duralast.......codes right off the bat.......changed out to ac/delco........codes gone !
Old 06-22-2013, 06:20 PM
ZForce1's Avatar
ok then. guess I'll swap them out 1 more time. It will be a good opportunity to paint my intake.
Quick Reply: Aftermarket knock sensors
