hanging exhaust, busted bracket ?
Hi guys,
So here is my issue, my exhaust basically fell off. I looked under the car and saw one clamp busted that basically connects right before the split to the cars. That part was hanging out.... then I noticed that the rear of the exhaust was swinging around (Bad), I looked under and the passenger side clamp that is attached to the frame of the car had basically broken off. Lucklily I didn't lose the rubber piece that stood inside the bracket.
here is my question, is this part that broke considered the exhaust hanger ? I searched online and found a few threads but not sure if this was the same piece others were looking for.
I called summitracing and they had some aftermarket piece that looked different and was only $7. I didn't buy it because I wasn't sure it was that especially since it was only $7 too.
Have any of you had this happened, and what was the correct part i need to replace, the name of it? thanks in advanced.
