What Tune-up Parts to Buy?
Hi guys/gals,
I'm preparing to tune up my first LS motor. The car has 73k miles, with an M6 and is stock except lid, bellow and 80 series crapmaster (soon to be replaced with a cat-back).
My plan is to change plugs, wires, PCV and all fluids. I was just going to go the stock route with AC Delco stuff but what do you guys recommend - especially on the fluids?
Also, any tips for changing all of this stuff is appreciated as well.
Thanks!
Thanks!
Castrol Edge Synthetic 5w-30, synthetic diff fluid, flush the brake fluid, power steering fluid too, and sythetic trans fluid. the more synthetic fluids the better, but not neccessary IMHO, BUT definitly use it in the engine. I use Mobil One high milage 5W30 with Lucas Synthetic oil stabilizer in place of one quart of oil(thats just me though) and motor runs wicked except the expected valve train noise. I know synthetics are controversial but we run synthetic oil in the turbine engines where i work and well, good enough for a turbine engine turning 18-22k rpm its good for anything. Id also pull the belt off (and the one for the a/c) and check the pullies, tensioner etc. oh yea, use distilled water and that Dexcool stuff when you flush the cooling system. distilled water=less minerals to react with the aluminum.
Fluids in my car:
Oil: Mobil 1 Synthetic
Trans: Mobil 1 Synthetic ATF
Coolant: Prestone
Clutch fluid: Prestone DOT3 (http://performanceworks1.com/ls1_clutch_bleeding.htm and http://forums.corvetteforum.com/c6-t...al-issues.html)
Rear: Lucas 85w-140 non synthetic gear oil with GM additive
Coolant: Prestone
Since you got a lid, I'm assuming you keep your Air Filter nice and clean, but make sure to check that also. When I got my car, it still had the original filter from 99', I'm surprised it even started A new one really woke it up.
As for fluids, I use Mobile 1 Synthetic Oil and regular prestone coolant. But fluids are fluids, just make sure you buy the right stuff and the brand is up to you
