Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Camaro and Firbird How to Repair Dash Vents That Don't Blow Air<br>Step by step instructions for do-it-yourself repairs.
AC and heater aren't blowing
whenever the car is stationary the ac and heater don't blow at all on any speed. when I'm on the freeway going at a constant speed, the ac and heater seem to blow fine. but when I'm driving around the city it doesn't work. anyone know what the problem might be? car is a 2000 trans am btw
Does it stop blowing when driving in the city or is going from the dash vents to defrost? If this is the cause it's probably the vacuum connector that controls the HVAC. Driving around town, starting/stopping your engine vacuum isn't constant. Driving on the highway it is.
On the HVAC box there's a vacuum line coming from the back of the intake, there's a black plastic connector with three ports going to it. If the vacuum lines are good and not broken replace that three port connector. It's a one way check valve, it keeps the HVAC controls from loosing vacuum when you accelerate.
