No heat???
No heat???
I just replaced the waterpump on my 2000 Z28. Now I don't have any heat. Is it possible that I swapped the 2 hoses on my waterpump going to my heater core? I've got all the air out of the system and it's running at normal temps. Any help would be greatly appreciated.
I would take both hoses off the two water pump ports......blow into each of them and coolant should shoot out of the other hose ends....... If it comes out no problem, it's not the heater core. I would also put the garden hose up to the end of one hose and see if water pushes and flows right through the heater core easily.....like flushing it out. Just do it under easy pressure.....not with a spray nozzle.
Did you change the coolant when you did waterpump. I had air in my lines last year and same problem. Bled air and it works fine. Either one or the other i imagine the heater core or air
