Battery question.....opinions.....
So I was away in Kuwait for 10 weeks and my girlfriend did not run my car enough to keep my battery charged......by the time I got home it was acting all messed up. It would hold a charge, then the next time I try to start the engine it's too drained to start. Had to jump it a few times.
So of course I took it back to Bennett where I bought it and it tested BAD, replace the battery.
So lucky me.....I was in my last month of free replacement......so I got a brand new 78-7yr for free.
QUESTION/OPNIONS:
I just had to leave again, this time ill be gone 7 1/2 weeks. I didn't have enough time last minute before I left to get a battery tender.....I parked it and disconnected both pos and neg cables. It's 3 weeks old and fully charged.
......You think that thing will be dead when I return???
Or will it hold the charge just fine and start right up in 7 1/2 weeks from now?
QUESTION/OPNIONS:
LS1Tech Administrator
Received 1,492 Likes
QUESTION/OPNIONS:
The battery in my Nova has been sitting disconnected since October, and I just checked voltage in it a few weeks ago......12.4x....after 4+ months with no tender connected. It was brand new as of last summer.
Even my '98's battery will hold enough charge (12+ volts) to start the engine after sitting connected for 4-6+ weeks without a tender. And that battery is 5 years old now. So yours being disconnected and brand new means that there should be no issues at all over that short period.
If a brand new, fully charged and disconnected battery is dead in 7.5 weeks, then it was a faulty battery.
ALL of the above responses are correct, BUT, IF you are going to be overseas for any other extended periods of time, I would invest in either a Battery Tender, or a CTEK for next time.
Your battery will last MUCH longer that way, and I would even plug it in overnight every once and a while even when you are daily driving it.
I got a CTEK for the motorcycle a couple winters ago. I really like it. I threw it on the Trans Am a couple times this past winter for a few days at a time. It made a difference when it was time to start it up.
I prefer not to start the Trans Am and let it idle just for the sake of the battery. I would rather have a battery tender on there.
I plan on getting another CTEK this fall and dedicate it to the TA. They offer a cigarette lighter adapter. I will probably go that route so I don't have to pop the hood just to connect/disconnect.
And..... I gotta say it..... no offense to anyone..... But, I would rather not have anyone else be starting up my TA while I was gone. If they are not car savvy and something goes wrong, you may end up with more damage than anything.
