engine knock i can't figure out
so i've had a noise for at least a couple thousand miles (through spraying etc)
it's loud and a "clapping" kind of knock from up top and seems centered to the intake. i can't figure it out... i'm about to pull motor to have freshened if i can't figure out...
1: new lifters (noise was there prior and post replacing them)
2: no bent pushrods
3: cut 2 filters apart and checked for elements and only found a small amount of metal and less the second filter.
4: hot idle oil pressure is no different than it ever has been and oil pressure seems fine
5:noise gets quieter as car warms up
any ideas? my guesses are cam bearing, bearings or bent valve? i don't really know...
2: no bent pushrods
