car didint start, clicking from glovebox
Old 09-13-2014, 04:39 PM
jts98z28's Avatar
Default car didint start, clicking from glovebox
okay, so i drove to work this morning with no issues, and 5 hours later when i go to take lunch break the car didnt start.
it was normal when i forst put eh key in, all the gauges were working and everything, then as soon as i went to start it everything just stopped. ive looked around and a lot of people have had a similar issue but radio and stuff still works, but my car was acting like it had a dead battery, no radio, no windows, gauges not even trying to move, no interior lights, and there was a very rapid clicking noise from what i assume is the BCM, about 1-2 times per second. when i took the key out and closed the door it stopped clicking, but if i had the door open and the key in the on position it stopped as well.
i assumed it was a bad battery but when i tested it, it had 12.7 volts. so i got my brother to give me a jump and it started right up, no problems and ran fine. i was even able to turn it off and turn it on a few minutes later without issue. but my main concern is this happening again, since i have no idea what it is does anyone have any suggestions?
thanks
Old 09-13-2014, 04:40 PM
jts98z28's Avatar
car is an 01 camaro z28, a4, only has long tubes back exhaust, and i disconnected the AIR
Old 09-13-2014, 10:18 PM
TX98Z28's Avatar
A corroded battery terminal or loose ground could do this. But if it's not that I'm stumped to.
Old 09-14-2014, 09:36 AM
Save the manuals!
wssix99's Avatar
This just happened to me yesterday in my truck. Corroded terminals were the cause.
Old 09-14-2014, 02:24 PM
jts98z28's Avatar
yea i looked at the wires coming off the battery and they look like **** and the car has the cheap soft metal like $3 battery terminals so i just bought new terminals and new wire for the battery cables
Thanks for all the input
Quick Reply: car didint start, clicking from glovebox
