Cold start issue.
Old 11-03-2014, 12:24 PM
Red97LT1's Avatar
Default Cold start issue.
Started the car this morning and it was cold, 25 degrees. Car started up and almost immediately wanted to die,so I gave a little gas it stayed running,but still seemed to want to to die. I'm thinking IAC valve. I also noticed that it didn't rev as high as it usually does when cold, it would got to to around 900-1000rpm when cold and drop to around 650-700 when warm. Once warm car runs fine.
Old 11-06-2014, 08:55 PM
Drag0's Avatar
Yeah sounds like IAC. But try and check to see if the maf is clean first. They usual cause the car to run rough.
Old 11-06-2014, 09:02 PM
Red97LT1's Avatar
MAF is clean. I just ordered a new IAC since I will be doing some work on the car this weekend. We'll see how it goes.
Quick Reply: Cold start issue.
