Serious Misfiring problem on 02 z28!
My 02 Z has been having random misfires for months that only happen when the car is in gear and you are rolling without your foot on the gas (Ex. sitting at a 4 way intersection waiting my turn to go with traffic having to stop and go constantly). I have replaced spark plugs, plug wires, pcv valve(which was broken) and had it checked multiple times by different people. Finally today I took it to a local shop. They told me that my car was having rotating misfires between ALL cylinders and also that my plugs were showing lean on one side and rich on the other side. I also find that weird because when I changed my plugs none of my plugs were running rich or lean. What causes this problem? Here is a list of my mods just in case they are needed. LS6 Tb, LS6 intake Manifold, BBK Headers, and a small tune on the computer done by East Coast Performance.
Any DTC codes? I've experience random misfires due to a MAF going bad once and also from a wire breaking on an o2 sensor. They both showed codes, though.
You can check the MAF by unplugging it while it's misfiring. If the misfire stops, that's likely your culprit.
