Power Mirror problem, operates in three directions!
Old 04-15-2015, 09:43 AM
92SilverSHO's Avatar
Default Power Mirror problem, operates in three directions!
Hey guys, just wanted to see if anyone else had this problem. My passenger side mirror only move up/down/left. Do you think a wire popped out of the connector or tore? If i take the door off is there anything i should be looking for on the drivers side door panel where the power mirror switch is?
Thanks!
Old 04-16-2015, 07:58 AM
Save the manuals!
wssix99's Avatar
You can start by taking the small black triangle off the door where the mirror screws in. (Just one screw.) The power mirror connector is right there and you should be able to test to see if the problem is inside the door or inside the mirror.
Quick Reply: Power Mirror problem, operates in three directions!
