Dash installation labor cost?
So my dash and the upper dash piece due to the intense heat and age has turned into peanut brittle. I have no desire what soever to put one in provided I can find a suitable replacement. So my question is, what kind of shop can I go to for something like this and what am I looking at as far as labor? I hope I'm not limited to a dealer.
Remove the two A-Pillars (the plastic panels against the frame of the Windshield on the driver side and passenger side of the car, they're held in by two bolts a piece and this is also the piece the T-Tops lock into.)
Use something flat and sturdy to wedge between the upper dash and lower dash crease and it literally will just pop right out, you have to pop it out in sections or it will crack but its very very very easy to remove. Its basically just velcro'd down. Only mild thing you need to be careful about it removing that alarm indicator from the center of the dash.
Install new dash in reverse.
