Help with fuel compression fittings
Does anyone know what the compression fittings on the fuel lines are for a 4th-gen fbody? Also if you know what style of flare is required, that'd be great as well. I assume it's a standard flare for these fittings.
See below photo.
Picture of three-way block, I believe the fuel filter has the same fitting as well.
Thanks in advance.
See below photo.
Thanks in advance.
