Creeks and Squeeks
Creeks and Squeeks
I don't know if I am just more sensitive to noises in my old age or if something is wrong, but ever since having some work done last year, I have been noticing all kinds of creeking noises on my 2000 WS6. Last summer I had a 12 bolt rear installed with new shocks and sub frame connectors. Now whenever I accelerate, brake, turn, or hit a bump I hear creeking noises or a cracking noise like a shock noise. I checked and the shocks are not loose at all. In fact they are very solid. Is it just the subframe connectors transferring forces around and causing flexing in other places? Are there some bushings that are wearing? I know these fbodies are rattletraps, but the noises are bugging the hell out of me.
LS1Tech Premium Sponsor
You really got to try to figure out what area of the car the noise is coming from. I know that I have personally dealt with sway bar bushings doing this to me before. I verified the issue by spraying lubricant on the bushings and the noise would temporarily go away.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
I would spray lubricant on one bushing at a time till you figured out exactly what the noise is. To me it sounds like a bushing deal or something that may be loose.
__________________
Glenn ***
Sales Tech
813.986.9302
Glenn ***
Sales Tech
813.986.9302
Im not really sure if this could be it but figured I'd chime in.......My rear Lower Control Arms did this when the stock ones were done with. I swapped them out for a set of lakewood LCA's and the noise went away. (and so did wheel hop lol)
