Jacking up to put blocks under wheels?
I need to get my car up on blocks, on the wheels, so it's sitting level and I can work on my new watts link and set it up like it would be on the ground. I have a QuickJack and large and small rolling jacks. My QuickJack raises about 18 inches but the wheels hang down, I can only get about 7 inches of clearance under a wheel. How could I safely jack up the axle or front to get about 11-12 inches under a wheel?
Another restriction is I can't build ramps and drive up on it, the transmission is out of the car.
Thanks for ideas.
link for quick jack if you haven't seen it: http://www.quickjack.com
Thanks for ideas.
What might be easier (and definitely safer) is to put stands under the front a arms, frame and then jack the rear axle up to compression and put stands under the axle. You can get your car even and then not worry about anything shifting with it balancing on blocks.
