Out Tail lights bulb socket?
I bought some new tail lights for my car and now that I'm about to install them, I discovered that my current tail light (the outer one) will not fit. It's too big. The tail light size that will fit in the new one is a Sylvania 194 or T10. Can I just buy the T10/194 connector and do some wire splicing and add it? Or am I better off boring my new tail lights to match my current tail light set up?
Here's a picture to illustrate what I'm referring to:
depends on the wiring and what was done previously? what is the tail light off of? I know I've heard of guys doing mods to squeeze a full size bulb into the outer bulb location on a firebird/trans am that required playing with the wiring so it would blink with the turn signals, if this is the case then you could in theory remove the wire that is tapped into the "bright" positive (positive power for brakes and turns) and rewire the negative and "dim" positive (parking lights) to a replacement 194 socket.
it really is up to you to decide how much work you want to put into it.
it's NOT a simple yes or no, it's an it's up to you if you want to lose the extra brake light/turn signal and just have a parking light in that position, so you either have to remove the extra wire (that needs to be identified) or modify the new housing to fit the bulb there, it depends on what YOU are more comfortable doing, like do you have the tools or know-how to test electrical circuits and determine which of the 3 wires running to that bulb is the turn signal/brake positive wire.
