Window Pulls "Away" from body of car above 75mph...
I have a very low mileage 1998 1SZ SS camaro that I picked up a couple months ago. The previous owner didn't drive it much and the car is quite clean but I'm also running into a bunch of little crap that needs taken care of. This is the first f-body I've owned that has manual windows, and I was stoked to not have to install AONTHER windowtrix kit and new motors, at least I was until I drove the car above 75mph. I can visibly see the window start to bow outwards away from the car. A bunch of wind starts rushing in like I have the window rolled down an inch or two, and then I lightly place the back of my hand against the widow and feel it flopping back and forth. I'm not sure what to do or what to check. I took the panel off to make sure that the little felt window guides were in one piece and adjusted correctly. No missing or broken stuff that I saw. Only happens on the driver's side. Any help/ideas would be greatly appreciated.
Save the manuals!
Something is broken. Those felt guides push the glass the other way, so they aren't going to be the problem.
Things to look out for:
- Classic broken roller (on the bracket that attaches to the glass) that engages the rear vertical track.
- Loose/broken regulator
- Loose horizontal track that bolts to the inside of the door
- Loose/broken door panel
