Coolant smells like a$$
What caused it to smell like that, and why does it stink up the inside of my car when I turn on the heat or A.C. I can understand why it would with the heat but Why the A.C? Also there is a red light on that I dont know what it is. It is a square with waves and an arrow inside it., the light is inside the tach area towards the top, guessing it has something to do with low coolant. The car is a 95 z28. Thanks. One more thing will flushing the radiator fix this?
Actually I did I didnt think about it till you mentioned it, but there was. If the heater core is leaking wont the carpet on the passenger side be wet?
depends on how bad the leak is. If it aint that much it'll just evaporate before it leaks all the way. Take off your glove box and the cover under it. You'll see the heater box. There's a couple of 8mm(?) screws you can take off and you'll get a clear view at the heater core. Changing it only requires that you take off the hoses that attatch to it on the engine compartment and also the few bolts that hold the heater core in place, an it just pops out. Well, not exactly pops, but you know what I mean. right?
