Fuel Rail/Injectors Assembly
I just recently took off my complete fuel rail assembly and regulator. I have a new fuel rail assembly and regulator ready to put on, but I was just wondering if you have to clean the injector "holes" (where the injectors connect on the manifold). Keep in mind that this is of an lt1 engine.
no u dont HAVE to clean them up. maybe just make sure theres nothing in there that will create a problem. however if ur installing ur injectors back in the manifold u better put some lube on the o rings on the injectors or u will most likely have a bad seal and create a vacuum leak. use vasoline, it has many uses ha ha.
