eng. sens. fuse?!?!?!?!WTF
Old 04-03-2006, 01:13 PM
mcamarols1's Avatar
Default eng. sens. fuse?!?!?!?!WTF
i keep blowing this fuse, and my check engine light comes on, the DTC's it gives me are p0102,p0803 (the maf, and the reverse lockout solinoiod) anybody have the same problem????
i also got my hp tuners but it did it when i went back to stock. it was doing it before but it stoped after i replaced the header gasket now its doing it again WTF??!?!?!?
any ideas??? thanx
Old 04-03-2006, 01:45 PM
2001NBMZ28's Avatar
Skip shift solenoid and 02s are on that circuit too - make sure you don't have a burnt/arcing 02 wire on the side where you replaced the header gasket.
Old 04-11-2006, 08:40 AM
mcamarols1's Avatar
it turns out it was the driver side front 02 sensor, since i got headers the 02 was rubbing on the heat sheild(that protects the brake line) and it shredded the wires on the bung. i replaced the 02 and i bent the heat sheild and cut it a bit so it wont happen again. the car is running strong now , especially after tuning it w/ HP Tuners, still got my wideband coming in cant wait to get my WOT nice and crisp!!!!!
